Replacing Pitman arm and Idler arm
Old Nov 28, 2010 | 04:39 PM
greatwhite's Avatar
greatwhite is on a distinguished road
Default Replacing Pitman arm and Idler arm
Anyone on here Replace Pitman arm and Idler arm? I have looked at it. Is it relatively easy to remove the dler arm if I only have the truck on Jack stands or do you really need a lift to get at part of it?
Also on the Pitman arm do I realy need to remove the steering gear? I was told if I am doing an alignment after I dont realy need to remove the steering gear and can just remove the arm from the steering.
Old Nov 28, 2010 | 08:07 PM
abig84's Avatar
If you have a impact it will make it way easier. You can leave all the lines and steering shaft bolted to the box you just have to unbolt it from the frame and twist it so you can get at the bolt then you need a pitman arm puller. But without a impact I don't think its gonna happen.
Old Nov 28, 2010 | 08:13 PM
greatwhite's Avatar
I have all the air tools (Impact) so that is not a concern. But I have never replace a pitman or Idler arm. (Done the ball joints and tierods).
So if I unbold the box I should be able to twist it to get in there with the impact?
appears to me for the Idler arm where the it is bolted to the frame there are two bolts, it doesnt look like I can get in there with the impact can I?? Or will a short bar work???
Bigest concern is can this be done lying on my back as the higest I can get the truck off the ground is about 18 inches with my 6 ton jack stands.
Old Nov 28, 2010 | 11:54 PM
abig84's Avatar
Yeah the idler has holes on the outside of the frame so you can get a socket in there
Here's a link about someone who did a pitman arm. Its a fe posts down
http://forums.s-series.org/viewtopic.php?f=21&t=47850
If worse comes to worse you will have to remove the gearbox if the puller won't take it off. Happened to me once
SmokedGhouda
Oct 8, 2013 01:17 PM
cartunez2004
Apr 9, 2011 09:01 PM
wild bill
Dec 25, 2010 02:02 PM
kornphlake
Dec 18, 2006 02:18 AM
RedOctober
Oct 11, 2006 09:00 PM
