Replacing rear wheel bearing
Old Aug 28, 2013 | 03:46 PM
mysain's Avatar
mysain is on a distinguished road
Question Replacing rear wheel bearing
how do I get the axle out?
Old Sep 1, 2013 | 06:44 PM
metalmeltr's Avatar
metalmeltr is on a distinguished road
These truck should have a c-clip rear axle, which mean the differential cover has to be removed. then you remove the bolt that holds the cross shaft in the differential so that the cross shaft can be removed. At that point the axle shaft can be pushed towards the center of the axle so the c-clip can be removed.
If I am wrong then removing the brake backing plates and bearing retainers will allow the axle to be removed by simply pulling it towards yourself. The brake backing plate will probably have to be removed either way.
brianp
Jun 1, 2020 10:30 AM
bigdaddykane93
Tires and Wheels
Mar 21, 2014 03:07 PM
ComputerNerdBD
Aug 30, 2011 10:59 PM
ComputerNerdBD
Tires and Wheels
Mar 5, 2011 05:50 PM
chvygirl84
Nov 22, 2008 03:03 PM
