Right front wheel question
Old Mar 8, 2007 | 11:03 PM
KIllarb634's Avatar
KIllarb634 is an unknown quantity at this point
Default Right front wheel question
Ok, I searched and dont really know if this is the same answer as the hub bearings.
98 blazer 4dr 4wd auto trans
Whats happening is fron the right front wheel it sounds like it is vibrating however i can not feel the truck vibrating, The truck has 17 inch rims with 275 70's on them, Rim is not bent and the wheel doesn't wobble at all, Tread wear is normal and not uneven. The car is pulling to the right a bit but not too much. Stopping is good and it doesn't pull while braking. I do get a little rubbing from the tire when the turning to the right but not the left. Any ideas will help
Thanks in advance
Brian
Old Mar 9, 2007 | 02:01 AM
Hanr3's Avatar
Default RE: Right front wheel question
Could be the bearings (hub assembly).
Jack teh tire off the ground. Grap it at the 12 and 6 o'clock positions and try to rock it up and down. Do you feel any movement? Of better yet, take it to an alignment shop and get a free front end inspection. Ask them to show you what they are looking for and how to find it.
Post up and we can help you from there.
smoothedoggie
Feb 15, 2009 06:07 PM
renskee1sfk
Jan 7, 2009 08:31 PM
cbetmark
Jun 30, 2007 07:09 PM
redpeppers
Apr 7, 2007 04:55 AM
keeskc
Jun 6, 2006 03:07 AM
