Squeak from right front wheel
Old Jun 30, 2007 | 06:59 PM
cbetmark's Avatar
cbetmark is an unknown quantity at this point
Default Squeak from right front wheel
I have a 2001 4x4 Blazer. Once the truck has been driven for 5 to 10 minutes, i randomly hear a squeak when coasting or while pressing on the accelerator. Any time I press on the brakes things are very quiet. I checked brake pad wear. Both pads have even wear and appear to have plenty of life left. I changed the brakes last summer and the wheel bearing was replaced by a dealer 1.5 to 2 years ago. Several friends said it was probably the bearing, but I wanted a "second" opinion before taking the time to change it. I have checked the threads about wheel bearings, none seem to have similar symptoms.
Any thoughts?
Old Jun 30, 2007 | 07:09 PM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
Default RE: Squeak from right front wheel
I have a similar problem that is probably a broken or loose engine mount... except my noise is more of a grind on hard takeoffs (merging, etc).
Check your engine mounts and make sure they are tight.
I you have a wheel bearing going out, it will likely roar insted of squeak.
94s10blazin
Sep 24, 2018 10:38 AM
WickedBlazer
Sep 12, 2012 03:14 AM
Green87S10
Jan 9, 2012 06:43 PM
thrash902
Sep 15, 2010 10:52 PM
Maynard97
Oct 28, 2007 07:56 PM
