Rim touches upper arm
Old Oct 16, 2012 | 02:31 AM
89 Blazer Lebanon's Avatar
89 Blazer Lebanon is on a distinguished road
Default Rim touches upper arm
I can't turn my wheels to maximum left without having the left front stock rim rub against the upper control arm. (2 pics attached)
I think (not really sure) it all started after I cranked the torsion bars, although it used to happen before the cranking, but only when wheels are locked to max left and down a steep hill.
I also changed upper and lower joints on both sides and have my upper ones flipped (mounted on the the control arms) but I had the previous ones mounted the same way for 3 years.
What could the reason be and what are the fixes for it (keeping in mind that I want to keep my T.B. cranked)?
Attached Thumbnails Rim touches upper arm-img_20120925_084452.jpg   Rim touches upper arm-img_20120925_084534.jpg
Old Oct 16, 2012 | 04:28 AM
newguy's Avatar
Old Oct 16, 2012 | 05:10 AM
Originally Posted by newguy
That's not a real fix!
Old Oct 17, 2012 | 11:29 AM
Update:
Today I went and checked the front alignment, needed some camber tuning on one side. After alignment, rim was still touching the upper control arm. The guy told me that the problem is the ball joints which need to be on top of the control arm, he also told me that I can grind some off the arm if I want to keep the joints flipped.
So I came home, tried to grind a very little off the arm (as I don't like the idea of messing up with the touching point as it's the bent part that gives the arm it's rigidity), still the rim was touching the arm.
I flipped the joints on both sides L & R to top of control arms, and the rim is still rubbing against the arm.
What should I do? Could it be the caster (the guy told me that it was good)?
Old Jul 8, 2013 | 05:03 PM
Jimmy's Jimmy's Avatar
Jimmy's Jimmy is on a distinguished road
Default Rubbing on control arm
Hey, I have the same issue currently. I have stock rims with larger tires and the RC lift and control arms. I have found out the only way to solve it is to get a different offset wheel or get wheel spacers. It sucks.
Old Jul 8, 2013 | 07:39 PM
newguy's Avatar
When you crank the t bar you pull the top of your tire in making your rim closer to the arm. sooooo,,, offset rims, spacers, or a longer upper control arm. Longer arms come with lift kits. Thats about all you can do
Old Jul 8, 2013 | 07:41 PM
newguy's Avatar
And cranking your tbars is not a real lift
Old Jul 8, 2013 | 09:27 PM
cleburne red's Avatar
Dang! Well played, sir!
Old Jul 9, 2013 | 01:33 AM
Thogert's Avatar
Haha, laughed pretty hard at that one.
evuldrporkchop
Mar 4, 2013 01:20 AM
cage47
Jun 11, 2010 12:17 PM
TripleBlackBlazer
Sep 19, 2007 08:48 PM
Marcin
Nov 11, 2006 10:03 PM
Major Pain
Suspension Tech
Dec 17, 2005 08:37 PM
