sas 85 blazer
Old Feb 14, 2011 | 05:44 AM
curkis535's Avatar
curkis535 is on a distinguished road
Default sas 85 blazer
i just did an sas swap on my 85 blazer. ( solid axle swap ) and i need to know if there is a pitmen arm i can get that doesnt have the ball joint in it. or if a fullsize blazer arm will bolt tho the gear box on the 85.
Old Feb 14, 2011 | 12:45 PM
abig84's Avatar
when i did mine i used a astro vanbox and used the stock pitman arm. its a identical box but i think its reversed rotation though... so that will work but it doesnt have a drop. depending onhigh you went it might work. i have maybe 9-10 inches of lift and it works perfect with crossover steering. the drag link is straight. but you might have to ream out the hole depending on what tie rod ends you used. i used the ones off a k5 blazer and had to make the hole bigger... even easier if you go with heim joints
91tbi4.3
Lifting Tech
19
Dec 14, 2012 06:58 PM
atvwarrior
Apr 22, 2012 03:48 PM
carlosblazer
Lifting Tech
16
Nov 21, 2011 11:51 PM
SldAxl85
May 26, 2010 01:08 AM
JAMES JONES
May 14, 2009 07:25 PM
