Seized rear brake caliper
Old Nov 4, 2007 | 01:00 PM
pigmak's Avatar
pigmak is an unknown quantity at this point
Default Seized rear brake caliper
thanks guys, so the caliper was def seized, i got a new one. I put it on but when i attached line (the square box thing) it leaks. i tried to get it as tight as i can but it leaks from right by that box thing. doesnt look stripped. new caliper came with 2 little washers, do i need one on inside and one on outside? i am so desperate this sucks
Old Nov 4, 2007 | 02:26 PM
Default RE: Seized rear brake caliper
Yes, you have to use one copper washer between the caliper and the banjo fitting, then another between the banjo fitting and the banjo bolt. You also need to make sure that there is not dirt or gouges in the sealing surfaces before putting things together.
offthewallds
Oct 9, 2013 08:15 AM
stlunatics2oo3
Aug 13, 2011 01:01 PM
toaks1
Sep 10, 2009 04:26 PM
pigmak
Nov 4, 2007 07:21 PM
lemon blazer
Aug 7, 2007 08:31 AM
