Serious vibration from rear diff
Old Sep 6, 2014 | 03:04 PM
DirtyBlue00's Avatar
DirtyBlue00 is on a distinguished road
Default Serious vibration from rear diff
I spun out last winter (live in IL) in to a ditch and my blazer was in a bind. It was sitting crooked in the ditch where if you were looking from behind the passenger side wheel was shoved up inside the wheel well. The driver's side was hanging down into the ditch. I got a hell of a vibration after and then I replaced the right side axle (it was bent). When I went to change the axle I looked closely at the center section and my spider gears look to be ate up more than normal. I drive on the highway to school everyday about 20 miles and it beats the **** out of me. Any ideas?
Old Sep 6, 2014 | 04:35 PM
newguy's Avatar
First thing, tires are balanced?
Old Sep 6, 2014 | 05:00 PM
rexazz2's Avatar
drive shaft make contact ?
Ujoint ?
Old Sep 8, 2014 | 07:31 AM
cctcct67's Avatar
cctcct67 is on a distinguished road
After bending a axle shaft I would check that rim and also pinion bearing and u joint too.
Old Sep 11, 2014 | 04:18 PM
Hey guys, my tires are balanced (All 4 Brand New). I myself and I had the guys at Firestone check to see if my rims were bent. I didn't think they were and neither did Firestone. I have checked the driveshaft as well, its true, no bend to it. However, the pinion bearing is vey loose. I don't think its a u-joint, the vibration for one is to violent, and two I have had them go out before and know what they feel like. Don't you guys think it's weird for my spider gears to be ate up more than normal?
Old Sep 11, 2014 | 07:26 PM
newguy's Avatar
If the pinion bearing
is bad, yes it will eat up the spider gears
Old Sep 13, 2014 | 05:37 PM
Blazin00LT's Avatar
Blazin00LT is on a distinguished road
Sound like the diff ate itself to death.
Sean Mahoney
Feb 5, 2014 08:50 PM
Fuz
Sep 25, 2012 06:47 PM
Doverman454
Aug 14, 2010 11:46 PM
offroadin00blazer
Suspension Tech
15
Sep 13, 2006 09:34 PM
jdpilot
Mar 28, 2006 10:52 PM
