shackle location, how to?
Old Oct 19, 2009 | 08:12 AM
lovemy01ZR2's Avatar
lovemy01ZR2 is on a distinguished road
Ok...finally! I got my shackles replaced. I used a grinder to fix the end of the bolt I screwed up, and heating them up with a torch gun and pounding the craaaaap out of it seemed to be the only effective way (besides cutting).
To start off with, I cut the exhaust pipe back past the shackles so the bolt would come off on the pass. side. I took the top bolts out first and loosened up the U-bolts to let the leafs go down further to give me more clearance while beating on the bottom bolt.
We heated the bottom bolt and whaled on it with a fairly large hammer and large nail set (just watch your hand, I have hammer head imprints on mine ). Eventually it came out. We repeated the process on the pass. side. The whole thing took us about 3 1/2 hours.
Old Oct 15, 2010 | 08:55 AM
Magri's Avatar
Magri is on a distinguished road
A tip for the future.... When beating on a bolt to get it out, put the nut on a few turns and hit that. It'll save you a lot of headaches dealing with mushroomed bolts.
Old Oct 20, 2010 | 11:45 AM
rob44_90's Avatar
rob44_90 is on a distinguished road
USE AN AIR HAMMER to get the bolts out!!!!! Literally took me 5 to 10 minutes to get both of the shackles off. I couldn't get mine to budge either and I was using a pretty big steel mallet to pound away with. The mallet and WD-40 did nothing for me. The air hammer is the only way to go IMO.
FIVEHORSE
Lifting Tech
Mar 17, 2013 01:46 AM
uncle larrys oranges
Lifting Tech
Feb 1, 2010 12:18 AM
jason1978
Nov 10, 2009 01:02 AM
flyinbrad
Suspension Tech
Jan 20, 2009 01:23 AM
vermillion2
Jun 15, 2007 10:24 AM
