shackle problem
Old Dec 22, 2008 | 03:53 PM
Psychropod's Avatar
Psychropod is an unknown quantity at this point
Default RE: shackle problem
Are there any how-tos on here about replacing shackles, preferably with pix? I ran a search but couldnt find one. Thanks.
Old Dec 23, 2008 | 03:59 AM
WolfPack's Avatar
Ive got one for a 2 door which has a few extra steps since one of their shackles is blocked by the gas tank...but the general idea is the same
http://www.zr2usa.com/mboard/index.php?showtopic=14200
Old Dec 23, 2008 | 10:04 AM
Psychropod's Avatar
Thanks!
Old Dec 23, 2008 | 11:36 AM
Black 1998 Blazer's Avatar
Black 1998 Blazer is an unknown quantity at this point
got the bolt replaced.
Old Mar 18, 2009 | 11:21 AM
vermillion2's Avatar
vermillion2 is an unknown quantity at this point
I had the exact same problem when I was tryin to put shackles on my Blazer. Same bolt too. Tried everything from drenching it in PB blaster for days, pneumatic tools, I called it quits after smashing the s*** outta my thumb with a hammer. Never did get around to lifting it after that.
Old Mar 19, 2009 | 01:25 AM
Cavalier z24's Avatar
Cavalier z24 is on a distinguished road
How did it work? i need to do my shackles because they are rusted with Hugh holes and i don't see how they are still supporting the weight lol but when that time comes i will be replacing it with new leafs and a 2" shackle
Old Mar 20, 2009 | 08:05 PM
Swain's Avatar
Swain is an unknown quantity at this point
I had the very same problem with the bolts, my advice would be try to get them out before you get your shackles. If you can't then there is a few ways to go. Torch the bolt(could and probably will work), get a shop to do it(weak), my method was angle grinder to cut the bolt, small drill to drill out the rubber from the bushing, hacksaw for the outter sleeve and hit it out with a flathead. Seems like a crappy way to go but if I just did that instead of messing around with that stubborn bolt it would have took me 25 minutes per side instead of all day pondering how to get the bolt out.
Of course I live in the east coast of Canada and they salt the roads heavily so my bolts were rusted in pretty good. By the looks of a lot of the trucks in the USA you may not have to go through what I did, either way it gets the job done and depending on the tools you have that may not be such a bad idea. Preorder some energy suspension bushings and you're good to go.
DarkKnightBlazer
Suspension Tech
Mar 29, 2014 07:48 AM
FIVEHORSE
Lifting Tech
Mar 17, 2013 01:46 AM
hateitorlikeit
Lifting Tech
Jun 9, 2011 10:08 AM
GrnBstrd
Lifting Tech
Jul 28, 2010 08:28 PM
jason1978
Nov 10, 2009 01:02 AM
