slack in steering wheel
Old Jul 20, 2015 | 08:20 PM
Redtortoise38's Avatar
Redtortoise38 is on a distinguished road
Default slack in steering wheel
I know there can be many causes for slack in a steering wheel, but where should I examine first? I can be going down a straight away, and the vehicle still wants to drift. (01' 2wd 4.3L) thanks.
Old Jul 21, 2015 | 08:53 AM
burned's Avatar
burned is on a distinguished road
Pitman arm, idler arm, rag joint, steering box, tie rods. Start with the first two they are the most common.
Old Jul 26, 2015 | 05:49 PM
Continue on , if necessary, to: All 4 ball joints, all 8 control arm bushings, sway bar end links, upper steering shaft universal joint, & center link.
Old Jul 26, 2015 | 06:54 PM
10-78 edac's Avatar
10-78 edac is on a distinguished road
And the power steering box
Old Aug 24, 2015 | 02:21 PM
pdxcrew427's Avatar
pdxcrew427 is on a distinguished road
Best bet is to lift one tire off the ground and find the solution instead of spending a bunch of money guessing. So lift passenger front tire off the ground and you should have no play moving wheel 3 o'clock to 9 o'clock and 12 o'clock to 6 oclock. If you have any movement find out where it's at and replace that particular part. After changing any steering components should consider alignment next. Hope that works for you.
ctyler
Aug 25, 2020 04:06 PM
chrisgascoigne
Jul 27, 2012 08:40 PM
litterbug
Oct 19, 2011 07:50 AM
Parilio
Sep 21, 2011 06:56 AM
caseroj
Oct 20, 2010 08:10 AM
