Sloppy Steering...
Old May 26, 2009 | 11:09 PM
jspafford's Avatar
jspafford is on a distinguished road
Default Sloppy Steering...
I bought the truck used with 172K on it. I just replaced the IM Gasket so now I can finally drive it.
I can turn the wheel from about 10-2 o'clock before the truck actually starts to steer in either direction. Also while traveling straight out of a turn the wheel is not in the center while maintaining a straight line.
Is there a common issue that plagues this type of truck.
My first GM, i've only had Fords.
1996 GMC Jimmy SLE 4.3L Auto 4WD.
Old May 26, 2009 | 11:21 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
this isnt and shouldnt be a common problem of any vehicle you deffintly have something loose/broken i would get it checked out asap or you can stick around and someone with a lil more knowledge will chime in and help point you in the right direction and give you some ideas of what to look at and check out.
Old May 26, 2009 | 11:47 PM
okvortec's Avatar
I recently asked about this same issue. Got some good input, could be the ball joints, need an alignment, steering slop, or the idler arm.
Check out THIS thread for more info.
Old Jun 17, 2009 | 11:35 AM
rsturge's Avatar
rsturge is an unknown quantity at this point
idler arm,pitman arm or tie rods
Old Jun 17, 2009 | 09:00 PM
Biohazed's Avatar
Power steering Box ... exact same issue my 95 has ....
Old Jun 22, 2009 | 11:36 PM
nasty187's Avatar
nasty187 is on a distinguished road
I have seen the steering shaft going to gear box wear out also real easy to check.go under the hood look for the shaft going to the box have someone turn the wheel back and forth while you look at the shaft may just be worn in or out however you look at it.Also ball joints tie rods ,pit man etc like the rest said.
Steve-o
Apr 17, 2014 09:59 AM
djschmidty
Nov 21, 2009 11:52 AM
88blackzcand95blazer
Dec 19, 2008 08:13 PM
BlazerChops
May 13, 2008 03:02 PM
timetoblaze
Engine & Internal
Oct 18, 2004 02:22 PM
