So it is NOT my 4hi/lo Switch...Right?
Old Jun 20, 2007 | 01:04 AM
WisdomRacing's Avatar
WisdomRacing is an unknown quantity at this point
Default So it is NOT my 4hi/lo Switch...Right?
1997 Jimmy SLT (No Auto 4wd...only hi and low)
So it goes like this. Switch would click and somtimes flash once but no engagement...did this for both high and low. I reset the power. After power reset, the light would flash a few times, and click, but then turn off. After it detected the fault however many required times (25?) it went back to it's old single click and occasional flash. Keep in mind when trying to get it engaged I put it in park, neutral...the whole schpeel. So I'm assuming this means it is NOT the switch correct? Can I also rule out the fuse then, too? I searched and found this brought up plenty of times...but no one really updates with what finally solved the problem.
Anyway thanks for any help guys!
Old Jun 23, 2007 | 03:06 AM
Default RE: So it is NOT my 4hi/lo Switch...Right?
Come on guys I'd like to get this taken care of soon. Any advice is appreciated.
Old Jun 23, 2007 | 05:41 AM
Have you checked out this thread:
OBD2 Non-Automatic Transfer Case Diagnostics
mjw1991
Feb 24, 2013 10:18 PM
rastoma
Oct 7, 2009 05:57 PM
Brickroad
May 26, 2009 05:46 PM
redpeppers
Apr 7, 2007 04:55 AM
