Speed sensitive noise from back end
Old Nov 10, 2007 | 06:19 AM
YukonJWP's Avatar
YukonJWP is an unknown quantity at this point
Default Speed sensitive noise from back end
2003 2 door Blazer, 4x4, 60k miles
I have a speed sensitive noise coming from the back end of my Blazer, whick started a week ago. The noise starts at around 65 mph, give or take a mile. It sounds like a buzzing noise coming from the passenger side around the rear wheel. It stays fairly constant, but will stop momentarily when a bump is hit or the road surface changes (like a bridge). As soon as I slow below the 65 mark, it stops. There is nothing extra back there, such as tool,etc. that would rattle or buzz. Nothing seems loose, also did a quick check around the wheel well and underneath, nothing obvious was seen. Has anyone had anything similar?
Thanks in adance,
Yukon
Old Nov 10, 2007 | 06:36 AM
Default RE: Speed sensitive noise from back end
I would really inspect the heat sheilds under the vehicle. This doesn't sound like hard part failure (wheel bearing, brakes, etc), but more of a trim peice or heat sheild that rattles a bit with increased air speed over it.
Old Nov 12, 2007 | 04:56 PM
YukonJWP's Avatar
Thanks, I'll take a look. Almost sounds like something came loose in the tailgate. Also, could shocks be a factor, maybe one going bad and causing extra vibration? Just a thought.
Yukon
Old Jan 20, 2008 | 08:43 AM
YukonJWP's Avatar
Everyone,
Finally found the problem, turns out the rear universal was bad, cheap fix and quiet again.
Thanks.
Old Jan 21, 2008 | 03:12 AM
thegr81's Avatar
Glad to hear you got it fixed!!!
Pipewrench Dale
Nov 10, 2014 06:16 PM
jdub9000
Jul 22, 2013 07:58 AM
schollianmj
Sep 25, 2012 04:02 PM
Psiegrist1
Jan 15, 2012 03:40 PM
