Squeaking while turning
Old Mar 19, 2011 | 12:07 PM
Darrylj's Avatar
Darrylj is on a distinguished road
Default Squeaking while turning
Hello everyone, I'm new to this forum and wanted to get some help.
I recently purchased a 2004 Blazer 4x4 2 door, I picked the vehicle up and drove away with no noises or any other kind of problem. After about 15 minutes of driving I started to hear a squeaking noise but only when I turn the wheel in either direction and I don't have to turn the wheel much at all to get that noise.
I had the vehicle inspected and all the ball joints, brakes and backing plates were replaced before i purchased the vehicle. Plus I greased every nipple I could find. Any ideas on what this could be?
Thanks in advance for any help or advise.
Darryl J.
Old Mar 19, 2011 | 12:42 PM
What kind of a squeak is it? Possibly the accessory drive belt on the engine or the power steering pump? Does it happen only when you are turning the steering wheel regardless of whether you are moving or not? Please try to be as descriptive as possible.
Old Mar 19, 2011 | 02:27 PM
Darrylj's Avatar
Yes, it happens regardless if I am moving or not. It sounds like its coming from the front end, and it sounds like a strut squeak really.
That being said I did have it inspected and the mechanic could not find any problems.
Darryl
Old Mar 19, 2011 | 02:42 PM
If it sounds more like a strut bearing squeak, then it likely in the pivot points of the steering and/or front suspension. Ball joints, tie rod ends (inner & outer), pitman & idler arm. Were you able to get grease to flow into all of the zerks at each of those locations? I believe there should be around 10 grease zerks total.
Old Mar 19, 2011 | 03:23 PM
Darrylj's Avatar
I got at 6 points that i could grease without removing anything (upper/lower ball joints, and tie rod ends) and the grease flowed easily. Good weather coming tomorrow so I will remove the impact plate and try to grease the others you have suggested.
I will post again with results, and thanks for your help. Cheers!!!
Darryl
Old Mar 21, 2011 | 11:03 AM
Darrylj's Avatar
Well, I have greased all points with regards to steering pivot points. Only other thing I can think of that would squeak while turning are the struts or strut mounts. The steering wheel realigns itself after turning so the mounts/bearings are good. Is it possible for them to go dry.
Coheed
Dec 13, 2011 10:46 PM
FireInMe17
Dec 24, 2010 06:34 PM
silver2002ta
Jan 3, 2010 11:55 AM
oisinirish
Oct 7, 2009 02:12 AM
Busted99jimmy
Jan 5, 2009 04:20 PM
