Stance upgrade
Old Apr 5, 2021 | 08:08 AM
Rickrickert's Avatar
Rickrickert is on a distinguished road
Default Stance upgrade
Looking for suggestions to take away that skinny wheel look and make em sick out from under the wheel wells a little to make ut look beefier.....any suggestions?what works best? Wheel spacers, wider wheels and tires, etc
Old Apr 5, 2021 | 10:19 AM
Do you have 2wd or 4wd? Stock rims?
Old Apr 5, 2021 | 09:53 PM
chagen's Avatar
chagen is on a distinguished road
I personally just got new rims. Spacers would be the cheaper way to go but rims are the better looking way to go. Changed my rims from a 15x7 to a 15x8 and they stick out about 2 inches now. Needed 1.25 inch spacers in the back to match the front though
Old Apr 7, 2021 | 01:25 AM
AJBert's Avatar
Assuming your stock tire size is 235/75/15, try running 255/70/15's. That will give you a beefier look and will not throw off the speedometer as they are almost the same diameter. As for sticking out past the wheel wells, if you like your Blazer clean, don't do it. If you do, both sides of your Blazer will be covered with anything that happens to be on the road as you drive. And I mean EVERYTHING.
Old Apr 8, 2021 | 11:07 AM
El_Beautor's Avatar
I'll second AJBert's suggestion of trying 255/70/15's on stock rims. They look way beefier than the factory 235's, and you don't have to worry about rubbing or changing your speedometer. I ran that size for 4 years on my Blazer.
Old Apr 13, 2021 | 02:38 AM
I have stock rims now but found a better set another
15in rims
Old Apr 13, 2021 | 07:33 AM
Those are nice and clean.
Also they are 2wd rims, so they will stick out in the front a little, and flush the tire with the body in the back.
Torbinator
Tires and Wheels
Apr 24, 2020 03:52 AM
98jimmyengine
Suspension Tech
Oct 7, 2018 10:35 AM
jeffbeckib
Tires and Wheels
Apr 30, 2011 08:57 AM
Frenchyap30
Tires and Wheels
Aug 16, 2009 09:17 PM
BlazerLS
Tires and Wheels
Nov 16, 2008 02:11 PM
