Steering linkage question
Old Feb 17, 2010 | 07:01 PM
R3MiX's Avatar
R3MiX is on a distinguished road
Default Steering linkage question
Ok guys, I'm not real familiar with this stuff (yet), but I'm wondering if you guys can tell me what the attached picture is. The part circled in red is the pitman arm(?) right?. The part circled in green is.... what?
If I need to take a better picture, let me know. gettin dark but I might own a flashlight. maybe.
Old Feb 17, 2010 | 07:03 PM
The red circle is the pitman arm. The green one is one of the tie-rod ends. This is also called a drag link on the SFA fullsize trucks due to its orientation.
Old Feb 17, 2010 | 07:15 PM
R3MiX's Avatar
awesome. any idea if the rubber bushing/spacer/thing between the pitman and the tie rod end is replaceable? or do i have to buy a new tie rod?
Old Feb 17, 2010 | 07:17 PM
That is just a cap. It does not carry load. Just keeps junk out of the joint.
I am not sure if that is available separately...
Old Feb 17, 2010 | 07:22 PM
R3MiX's Avatar
So, maybe I should explain more of what my issue is. I have alot of play in the steering wheel. I had a friend turn the wheel while I watched what was moving/not moving. What I've come up with is that the play is right there, where the tie rod end, and the pitman arm connect. How would I go about correcting this? new tie rod end? new pitman arm?
Old Feb 17, 2010 | 08:06 PM
If there is play in the joint, you need to replace the tie-rod end.
Old Feb 17, 2010 | 08:25 PM
R3MiX's Avatar
my assumption is that would be the outer tie rod end?
Old Feb 17, 2010 | 08:30 PM
Search for 'Drag Link' at your favorite parts store (I just did it for a '79 K5 at NapaOnline.com). It will come up as either 'at pitman arm' or 'at steering arm'. You may want to do both at the same time. Loose steering connections can lead to the infamous 'death wobble' in these trucks.
Old Feb 17, 2010 | 11:12 PM
R3MiX's Avatar
i may have experienced the death wobble already, happens about 35-40 mph. the 40" tires on it dont help at all really. Dual steering stabilizer fixed that problem though. but now its time to get to the root of the issue, and work on the elec short :/
dpannazzo
Jan 4, 2014 11:30 AM
error_401
Jan 12, 2011 03:35 AM
JTalley
Dec 15, 2010 12:03 PM
JTalley
Nov 22, 2010 12:31 PM
soundguy
Jul 31, 2007 03:59 PM
