steering wheel is loose to the rt
Old Mar 11, 2009 | 11:09 AM
boomer11's Avatar
boomer11 is on a distinguished road
Default steering wheel is loose to the rt
I recently replaced the lower ball joint, pitman & idler arm all on the rt side. Also both sway brace kits. The allignment has been done, but my steering is still loose the the right 10-15 deg(est).What could cause this?
Old Mar 11, 2009 | 11:10 AM
The only thing that would cause this is the steering box. How loose is it?
boomer11's Avatar
Thanx
Old Mar 11, 2009 | 11:22 AM
Cavalier z24's Avatar
Cavalier z24 is on a distinguished road
Originally Posted by boomer11
Thanx
lol no answer to how loose is it?
Old Mar 11, 2009 | 11:45 AM
boomer11's Avatar
10-15 deg before it starts turning
Old Mar 11, 2009 | 11:51 AM
Ok, that is not what I would classify as loose. I would call that a dead spot. Only being to one side is puzzling though. There is an adjustment that can be done to the steering gear box to tighten things up, but it typically is done with the gear box on the bench, not in the vehicle. If screwed up, you will be getting another steering box.
Old Mar 11, 2009 | 12:05 PM
boomer11's Avatar
How much would that typically set me back?
Old Mar 11, 2009 | 12:20 PM
Which part, replacing the steering gear box, or finding a mechanic who actually knows how to adjust a reciprocating ball steering gear box and having him do the work required?
Old Mar 11, 2009 | 12:38 PM
boomer11's Avatar
Either way...
I'm looking at abput $400 bux for the part alone,right?
Old Mar 11, 2009 | 01:09 PM
No. If you find a mechanic who knows what they are doing and can adjust it either on or off the vehicle, you may be looking at a marginal labor charge. Should be around 2-3 hours if they have to remove it, but quite a bit less if the mechanic is confident enough to be able to do it on the vehicle.
