steering wheel is loose to the rt
yeah it should not cost you too much cash a lot less then 400.00
you can do what I'm doing with my PS box i got approx 5-6 inch play in mine getting a junkyard box with a guarantee for $60 lol
Check the "rag joint" on the intermediate shaft on the steering column. It's under the plastic cover at the end of the column to gear box. Oil contamination (leaky hose that runs right above it) can soften and/or destroy the join and cause free play in the steering.
Thanx for the advice guys I'll look into it & post an update if i find something.
I seem to have the same issue. With the wheels straight ahead, the truck parked, it is tight and immediately begins to turn to the right, but has about 15 degrees of play to the right before it begins to turn. When jacked up the right wheel does have some play in it.
litterbug
10-19-2011 07:50 AM
ussexplorer
04-11-2010 06:53 PM
vze4yrte
03-16-2010 11:25 PM
HYPA
09-03-2009 01:49 AM
