stressed metal noise
I have a 2005 Chevy Blazer 4 WD, 5 speed manual transmission .... there are noises that sound "like metal that is being stressed" coming from the rear driveshaft. I looked at the driveshaft and turned it under my own power and I could hear the same noise.
To be specific, the noise I hear is more prominent when I am just taking off in 1st and 2nd gear (under the most torque I guess is the best way to describe it).
When I am in reverse I not only hear the stress noise but also a whining as each revolution of the driveshaft goes by.
If I take it out of gear and let it coast in reverse the whining noise goes away.
Any idea what this is and what I need to do to fix it?
Thanks.
Thanks.
My first guess would be the u-joints. They are easy enough to check and cheap enough to replace. Check them by dropping the driveshaft. If any of them feel tight or gritty, replace them. It's best to just replace both the u-joints while you have it out.
I was told the same thing from some others ...prolly the front u joint ..... I'll post up my results when done...thanks
my apolgies for not finishing this thread
it turns out it was the u-joint .... all was good immediately after replacing it.
the front one was fine and as such was not replaced even though I repeatedly asked the shop to just do it while we had everything out
anyhow, I was happy with their service and costs
ComputerNerdBD
02-29-2012 08:09 PM
blazinloud
24
10-01-2011 05:33 PM
ESKYMOPACK
14
03-27-2009 09:42 AM
