stuck axle nuts
If you are going to heat the nut, do not attempt it with a small little propane or map gas torch. The temperature is not high enough, nor is there enough heat flow to heat just the nut enough to break it loose in most cases. A good oxygen-acetylene or oxygen-map (oxy-map is overkill, but what we use in our shop) torch with a rose-bud tip would allow you to heat just the nut quickly enough to minimize the heat transfer through to the bearing assembly and CV shaft.
Also, it might be time to invest in a quality breaker bar. I have broken plenty in all of the time I have been wrenching, but they have all been L-cheap-O bars. Snap-On, Mac, and other quality forged bars would be of benefit to your tool collection.
thanks for the help finally got 1 nut off the problem i am having now is i watched so many vidios that i am not sure what to do next. I am trying to get to bottom ball joint have brakes and rotor the 3 bolts out of bearing hub the way i understood it i was to knock shaft in and the pop off bearing hub.Shaft went in some and bearing hub wont move could some one please guide me through this this has been a real pain any help would be appreciated this is a 98 ls blazer 4wd
To pull off hub use a slide hammer puller. Thats how I got mine off. Theres a rubber seal that really sticks that hub to the spindle. I believe you said you already removed the hub bolts so it will just pull off with axle nut removed.
You should feel lucky
All of the pressure is pushing in on the axle, right into the differential... not good, results can be disasterous to the differential. Same reason you should never beat on the axle to break it loose from the hub, until the hub is at least partially removed from the knuckle.
To loosen the axle nut: Never use an impact, you're liable to damage a CV joint and or teeth on the ring and pinion. Before you remove the rotor and caliper, stick a screwdriver through the caliper bracket and into one of the rotor vanes. Or, remove the nut while the wheel is still on the ground. Both of these methods will hold the axle securely when you loosen the nut, rather than relying on the differential.
All of the pressure is pushing in on the axle, right into the differential... not good, results can be disasterous to the differential. Same reason you should never beat on the axle to break it loose from the hub, until the hub is at least partially removed from the knuckle. To loosen the axle nut: Never use an impact, you're liable to damage a CV joint and or teeth on the ring and pinion. Before you remove the rotor and caliper, stick a screwdriver through the caliper bracket and into one of the rotor vanes. Or, remove the nut while the wheel is still on the ground. Both of these methods will hold the axle securely when you loosen the nut, rather than relying on the differential.
