stuck axle nuts
Old Dec 25, 2013 | 08:29 PM
Nope. The inboard end of the axle goes into the differential. If you hammer on the cup, the shock goes right into the differential. If the axle is seized in the hub, partially remove the hub. That will pull the axle away from the differential. Then use a wheel puller. The ram bolt fits into the cup. As the axle moves inboard, pull the hub outward. Gotta keep clearance between the end of the axle and the differential.
Old Dec 25, 2013 | 10:30 PM
odat's Avatar
bearing bolts were removed so there was freeplay on axle to the differental - I had destroyed a puller before i installed press
Old Jan 1, 2014 | 01:53 PM
apaplayer's Avatar
apaplayer is on a distinguished road
i have pushed axle in about an inch still cant get hub to break lose is there some kind of puller to put on to pull it off
Old Jan 1, 2014 | 08:51 PM
A VSP, (variable swinging press) works well, (aka a BFH). Might try some PB Blaster, and or heat. Make sure you have all three bolts removed from the hub
86bigred
Mar 20, 2015 09:50 PM
megtom2
Oct 30, 2007 02:47 PM
rjayflo
Jun 25, 2007 09:41 AM
nofear17bmx
15
Dec 20, 2006 03:14 AM
skitzobmxr
Dec 20, 2006 01:15 AM
