Stuck key in 91 Blazer
Old Jul 20, 2012 | 01:53 PM
Conroy's Avatar
Conroy is on a distinguished road
Default Stuck key in 91 Blazer
The ignition key is stuck in the run position. Had to pull the coil wire and disconnect the battery to stop the vehicle. I suspect it's linked to the gear shift (column mounted) not getting to Park. However, I've disconnected the linkage at the transmission, and jammed it back to Park as hard as possible.
Also, pulled the steering wheel off, but i can't release the lock by pushing in the little silver button. took the switch off the bottom end of the steering column, but that seems to be working correctly.
I'm pretty sure it's a mechanical problem because the key switch seems to hit such a solid stop when I try to turn it back.
changeme20
Oct 24, 2020 02:12 AM
stingray74
Mar 5, 2015 08:27 PM
dagsler
Aug 10, 2010 08:25 AM
tryntofixmykidsblaze
Feb 27, 2008 07:51 PM
klein
May 5, 2007 04:03 PM
