Subtle Popping on level ground (LH Front)
Old Feb 24, 2009 | 11:17 PM
fondo's Avatar
fondo has a little shameless behavior in the past
Default Subtle Popping on level ground (LH Front)
When ever I'm going at slow speeds and I'm on level ground I get this very subtle popping from the front left side of my '93 olds bravada. I thought it may be my upper ball joint so i replaced it (as I did the lower a little while back) and still have this popping. It drives me f#@!*!# insane when I hear it. Could this be in the steering linkage even though everything seems to be solid. I also did the control arm bushing not to long ago (both sides, both arms). WTF is this. Thanks
Old Feb 25, 2009 | 01:08 AM
quik1964's Avatar
quik1964 is an unknown quantity at this point
Default RE: Subtle Popping on level ground (LH Front)
have you considered that it might be front axle shaft, those joints take a lot of abuse.
Old Feb 25, 2009 | 07:08 PM
fondo's Avatar
It very well could be that considering that this is an awd and these axles are constantly under load. Good suggestion...
eljorgin
May 21, 2019 10:04 PM
Rumblur
Jan 18, 2014 05:45 AM
TennesseeBoy
Jan 7, 2014 07:22 PM
pettyfog
Suspension Tech
Apr 20, 2012 07:54 PM
cide
May 1, 2009 01:07 PM
