Swap gears???
Old Aug 29, 2013 | 12:00 PM
Jimmy_Blazer's Avatar
Jimmy_Blazer is on a distinguished road
Default Swap gears???
Ok So I have the 95 4 door wit hthe stock axle (don't know what gears it has in it) But I was wondering if I find the axle of a Zr2 if I could take the gears out of that and swap it into my differential. You're probably wondering why would I do that if I can just swap the axles out, well with the wheels I have they stick out pretty far and if I get the Zr2 axle under it they will stick out almost all the out, and I don't want to have to hunt down new wheels. So anyway, what kind of work will have to be done? Will the Zr2 gears work with the stock axle shafts currently in my truck? If I am completely crazy for doing this say so and I'll consider just doing the whole axle swap.
P.S. I do know I will have to change the front differential as well.
Old Aug 29, 2013 | 05:25 PM
chris015's Avatar
i think i understand what you are saying. I dont think the rings and pinion will fit. And the whole rear end will be wider. you could swap the whole rear,then get a different set of rear rims with the right backspacing to make it look right.
Old Aug 29, 2013 | 07:21 PM
Jamaroon's Avatar
You have a 7.5" rear end, ZR2's have a 8.5" rear end. So no, you can't swap gears between the two.
Some normal blazers did come with an 8.5" rear end, so you could try finding one of those and then swap to 3.73 gears to keep the width down. I think if it was a standard transmission it was more likely to come with it. blaz's blazer is bare bones for options and is a standard and came with a 8.5
Old Aug 30, 2013 | 08:52 AM
Ok, what gear ratio do I have in my blazer now (if you would know) I know the ones from a Zr2 will help with the tires since I'm running 31x10.5s
Old Aug 30, 2013 | 10:36 AM
Jamaroon's Avatar
Most common is 3.42 You can check the codes in your glove box. Search for gear codes in the forum, I don't know them off by heart. I think 3.42 is code GU4.
Ronman105
Jan 7, 2013 03:48 PM
James1965
Jan 16, 2012 11:32 AM
97blz4x4
Jan 22, 2007 04:16 PM
DS01blazer
Headers, Intake, & Exhaust
Oct 23, 2006 02:52 AM
timetoblaze
Sep 25, 2004 01:11 PM
