swapping axles for better performance
Old Nov 17, 2012 | 02:04 PM
cali bear 87's Avatar
cali bear 87 is on a distinguished road
Default swapping axles for better performance
I have a 00 blazer 4x4 I don't know what are the gears the axles should have stock because the code in the glove box is faded my gears broke so I bought a used diff from a wrecking yard with 3.42 ratio I have some 31x10s mud tires on what are good better gears for my blazer I wanted to swap the front and rear gears from a zr2 I'm new to 4x4 do I also need to swap the transfer case I just want to be able to push these tires good I do have a heavy foot on the gas pedal specially driving to work
Old Nov 17, 2012 | 02:34 PM
Diaita's Avatar
Your blazer probably has 3.42 gears right now. The zr2s have heavier differentials and 3.73 gears. The gears and difs you have now will be fine with 31s. 4.10 gears would be ideal.
Old Nov 17, 2012 | 04:17 PM
neo71665's Avatar
My blazer had 3.73s and with 31s I had no complaints. If I was swapping gears I would go fo 4.11s
Old Nov 17, 2012 | 05:02 PM
tdbone1's Avatar
tdbone1 is on a distinguished road
i dont know if we are allowed to ask this (not sure about the rules) but my blazer (1999) 3.42 gears with the slip on cv axles (not the bolt on).
if you can figure out if your blazer has 3.42 i would be intrested in a few parts off the passenger front diff axle
the clutch sleeve and clutch gear and prob the spacer
the boneyears here want to sell you the whole diff when all i need is a couple parts in it.
if i were to get the parts new from gmpartsdirect they want almost $100
anyhow i would be intrested from anyone really to get the whole passenger side axle asseble (not inc the cv joints)
litterbug
Aug 25, 2011 11:18 PM
chris015
Engine & Internal
Jul 25, 2011 09:13 PM
danmcph
Apr 2, 2010 07:01 PM
slicer4559
Jun 20, 2006 05:38 PM
webbyj883
Suspension Tech
Sep 9, 2005 02:15 PM
