T-Case fluid
Old Dec 24, 2007 | 05:25 PM
jcheil's Avatar
jcheil is an unknown quantity at this point
Default T-Case fluid
Ok, I replaced the fluid in my T-Case this weekend but then saw a bunch of posts here about different kinds of fluid. So, can someone confirm that my transfer case uses standard ATF. It is an '89 S10 blazer, 4.3L 4x4.
Also, I drained the T-Case and got out justover 3 quarts, however, it barely took 2 quarts to refill and it was coming back out the fill hole. Thoughts?
Thanks,
Jay
Old Dec 25, 2007 | 12:10 AM
Default RE: T-Case fluid
Did you remove the fill plug before you removed the drain plug? It is possible that the transmission rear seal is bad, allowing fluid into the transfer case, causing your over full condition.
Your transfer case uses straight ATF fluid. It isn't until the newer auto4wd and AWD transfer cases that the GM Autotrak 2 fluid is required.
Old Dec 25, 2007 | 12:50 AM
drperry's Avatar
I think even the newer 3 button t-case can use ATF, but I can't remember for sure...
I know it could use autotrac II, and that's what I put in, because it's blue... Not the best reasoning for the cost, but, oh well, lol.
Old Dec 25, 2007 | 07:41 AM
jcheil's Avatar
ORIGINAL: swartlkk
That does make sense. No, I drained it before opening the fill plug.
Do you think it sould hurt to leave it alone even if it was leaking? I only use this vehicle in the woods a couple of times a month.
BrinkDiamond
Mar 2, 2014 03:50 PM
DaleA
Jan 13, 2009 08:50 PM
AutomagicLS1
Engine & Internal
Dec 1, 2006 11:08 PM
blazerium
Nov 20, 2006 11:10 PM
Marcin
Oct 14, 2006 06:09 PM
