taking out my driveshaft
Old Apr 4, 2010 | 10:35 AM
giaco's Avatar
giaco is on a distinguished road
Default taking out my driveshaft
i have a 2000 jimmy 4wd, how do i take out the driveshaft, 4 bolts on the rear axle side? and what about the transfer case side?
Old Apr 4, 2010 | 01:07 PM
Brandon43's Avatar
Brandon43 is on a distinguished road
If I am correct, once you take out the 4 bolts holding the u-joint to the rear differential, then you're driveshaft should just be able to lower it and slide it right out of the transfer case.
Old Apr 4, 2010 | 03:24 PM
old skool luvr's Avatar
that is correct Brandon.
@ giaco; just be sure to wrap some electrical tape tightly around the u-joint before you "pop" it out of the diff's yoke. 3 or 4 wraps will do-remember to keep the wraps tight (it'll keep the cups from falling off).
also have a small pan under the back of the t-case to catch the little bit of trans fluid that will come out.
Old Apr 4, 2010 | 05:03 PM
giaco's Avatar
guess i gotta give it a wack then. must be stuck there. Thanks guys for the replys
gitch93
Jan 23, 2013 04:51 PM
higgy
Nov 29, 2009 03:09 PM
runnin blazer
Nov 17, 2008 02:29 PM
slickster01
Jul 22, 2008 07:48 PM
ivannj
Engine & Internal
Jan 20, 2006 10:52 PM
