TCCM Fuse
Old Nov 12, 2012 | 02:06 PM
ChrisNick78's Avatar
ChrisNick78 is on a distinguished road
is there a way to manually shift it into 2wd at all check all the vaccuum line and they all look good but i did notice there is one open line that goes no where cant find any ports its by the booster new the abs. and i dont have the vaccuum ball that everyone talks about did they not use that set up in the 2000 blazer lt
Old Nov 12, 2012 | 02:40 PM
tmnc78's Avatar
tmnc78 is on a distinguished road
This is hard to explain but i'll try my best. Directly behind and below the abs on the wall of the engine bay is a vacuum nipple, you cant see it and will have to feel in that area to find it. If that one is connected it could be the one that goes to the manifold right below the intake pipe.
Old Nov 12, 2012 | 03:08 PM
ok i think i know the one your talking about. i'll try to take pictures tomorrow to better show you. thanks guys so much for all the info
Old Nov 14, 2012 | 08:42 AM
does one of the vacuum lines go to the heater control? and do you have to remove the front drive shaft for the t-case motor if so how do i go about doing so
Old Nov 15, 2012 | 09:01 AM
can i drive my blazer without the front drive shaft and t=case motor in it or will it leak fluid
Old Nov 7, 2022 | 02:06 PM
Bigbill1204's Avatar
Bigbill1204 is on a distinguished road
I'm haveing the same problem.dont mean to hijack yours .. I have a 2001 blazer .Ls when I hit 4hi I hear clicking coming from passenger side kick panel .the light flashes and goes back into 2hi I hear no sound coming from the tranfer case i put in neutral and hit 4low same thing clicking in kick panel no sound from tranfer case i have all imdercater lights but wont swich just go back to 2hiI have good vacume new tccm good Power please god help me worked fine and few months ago and boom nothing I'm lost and dumb founded I'm 52 and do all the work on my vechiles my self always have but I'm stumped on this one
Old Nov 7, 2022 | 02:09 PM
Originally Posted by ChrisNick78
Hey all im haveing problems with my 4wd i can hear the click when i go from 2wd to 4hi no click going from 4hi to hlo. and the light is flashing. i did some reading up on it lastnight. my question is where do i find the tccm fuse or do i disconnect the tccm
If you figured it out please let me know I'm in same boat .bigbilly1204@gmail.com thank you
Old Nov 7, 2022 | 04:00 PM
Stovey's Avatar
Stovey will become famous soon enough
This thread is ten years old!
The TCCM fuse on my '98 is the 10 amp courtesy lamp fuse found on the left side of the dash. There is also a 4WD fuse under the hood. The system can be reset by removing both fuses, waiting some period of time, replacing the fuses, and turning the ignition to run 5 times before starting the vehicle. For me, this reset procedure seemed to repair 4WD temporarily ie one shift and that's it.
You could work through the diagnostic procedures provided in the tech articles to pinpoint the problem.
https://blazerforum.com/forum/tech-a...e-first-30093/
Old Nov 7, 2022 | 04:39 PM
I've tried the 5 time thing and nothing lights still just flash and I hear the clicking under passenger kick panel no matter if I do 2hi 4 hi or 4low .just clicking in kick panel nothing from tranfercase .am I missing something 2001 blazer new tccm .it seems to not getting thing to case what should I do next .please help
Old Dec 1, 2022 | 02:24 PM
scooby's Avatar
scooby is on a distinguished road
Did you figure out the solution? I have the same problem. The clicking sound is a relay in the TCCM. I replaced the relays but still have the same problem. I don't want to buy a new TCCM if I don't need to,
Joann
Oct 14, 2013 10:33 AM
AustinBlazer
Jun 4, 2013 10:35 AM
Tinted
Nov 29, 2011 02:06 PM
06marbleRR
Feb 23, 2010 04:41 PM
vrryder
Dec 29, 2009 11:34 AM
