Trying to figure out if TCCM or Encoder Motor
Old Nov 10, 2013 | 02:22 PM
Helter80's Avatar
Helter80 is an unknown quantity at this point
Default Trying to figure out if TCCM or Encoder Motor
I have read a lot on this, but still have trouble. After a couple of times going in and out of 4HI, and 4LO on my 2004 Blazer with the 3 button 4 wheel drive, I then cannot get it out.
It's either stuck in 4HI, 4LO, or 2HI. If I disconnect the battery, then reconnect it, the 4 wheel drive system works fine again for a few times, then gets stuck again.
I've tried this before which I've read in a thread here I pasted below but still no luck.
It will perform it's normal system check when I start the truck, none of the lights light up when I ground the #13 pin on the OBD II port. So I assume there are no codes? Here is the thread I was talking about:
EDIT: When I ground terminal #13, the system does it's normal check, but none of the lights come back on, or blink. They stay off. BUT when I do not ground the #13 terminal and it does its normal check, after the check is done, the 2HI stays on.
For OBD-II vehicles with push button between the instrument panel and the radio/HVAC control stack:
The diagnostic trouble codes are displayed on the three transfer case shift select buttons located on the instrument panel. When the connector pin 13 on the data link cable is grounded, and the ignition switch has been OFF for at least five seconds prior to positioning the ignition switch to run the shift select buttons will blink various times together in order to indicate a diagnostic trouble code from 1 to 4.
Position the ignition switch to OFF. Ensure the ignition switch is positioned to OFF for at least 6 seconds. Connect pin 13 on the data link cable to a vehicle ground source. The data link connector is located in the cab under the instrument panel on the driver's side. Position the ignition switch to RUN. Note the shift select buttons for blinking codes.
If the shift select buttons all blink one time and stop, and do not continue to blink, no fault codes are stored in the TCCM. The transfer case shift select buttons will blink in order to identify any stored trouble code. If only one code is stored in the TCCM memory, that code will blink repeatedly with a three second delay between blinking sequences. If more than one code is stored, the first code will blink once, then after a three seconds delay, the next code will blink. This sequence will continue until pin 13 is no longer grounded.
When reading the diagnostic trouble codes, the number of shift select buttons blinks will indicate the code number.
The error codes are:
1 - When the ignition switch is positioned to RUN the TCCM test to determine if RAM standby Power (maintained battery power) to the TCCM was lost since the ignition was last turned OFF. When power is interrupted on pin C6 of the TCCM, the TCCM stores a loss of RAM standby power.
2 - During electronic shifting, the TCCM check the motor/encoder for normal operation. If the motor/encoder does not function correctly enough times, the TCCM stores a motor/encoder failure DTC 2.
3 - The TCCM performs a test each time the electronic-shift motor is turned ON or OFF. If the motor does not function properly the TCCM stores a motor circuit failure DTC 3, and the shift select buttons blink in order to inform the driver of a problem.
4 - Each time the ignition is turned ON, the TCCM tests the memory, the program, and the internal system in order to ensure that the TCCM is operating properly. If the TCCM detects a fault within the TCCM, the TCCM stores a RAM/ROM memory failure (DTC) 4.
Old Nov 14, 2013 | 06:15 PM
Helter80's Avatar
Anyone?
Helter80
Dec 23, 2024 10:04 AM
Zweber450
Feb 13, 2018 07:25 PM
skidud
Feb 9, 2014 05:46 PM
Helter80
Nov 15, 2013 05:17 PM
millernet
Aug 19, 2010 08:48 PM
