Tink and rattle sound
Ok on my 19974x4 blazer lt with 157k on it. When i turn it will make a tink and then when you excelerate it will have a rattle sound to it seems to be coming from drivers side rear end??? I just had the front upper and lower ball joints replaced 6,000 miles ago. Any ideas what it is and it does not do it every single time. The rattle goes away if it happens after you reach 25-30miles an hour.
Hello Janddcunningham,
Not sure if you noises are like mine or not. I have been getting a tinkering from under
my car also. It also comes and goes. I can hear at especially when I first start out
After the car is running and warmed up.
Once it's there it stays. I first thought it was coming from my transfer case.
Yesterday I topped off the Transfer case with fluid just to make sure it was filled.
It was. I also put new universal joints on only because my vehicle needed them.
They were the originals. I also did a Trans filter and fluid change for regular maintenance.
And also checked the front Differential to make sure it was topped off. It was.
When I had it over at the Repair shop, it would not make the noise. We had it up
on a hoist. Maybe it needs to be under load.
I'll have to take it back over to the shop once it appears again when I get the chance.
My noise really sounds like a tinkering then rattling also as you increase the gas.
Mine kind of appears after the car warms up a bit. It sound pretty noticeable at very low RPMs.
But like yours it comes and goes.
Well anyway I will be watching you post.
If I come up with anything I'll let you know.
Mark K
Mark K
Ok i am thinking i may of found my problem??? On the driversside rear tire there is a wire like thing that runs under the frame to the tire it is rubbing and it squeaks looks like it is about to rub right in half i have pics need to learn how to upload using my phone.
http://i1086.photobucket.com/albums/...7238356622.jpg
I had all the breaklines replaced a yr ago this braided looking thing goes to the tire and looks to be a replaced breakline? Not positive however.
Ok so i worked on that and i believe i have it fixed and not rubbing both parts in half however i still have me rattle not as bad but still there.@ mark i am now going to look into the wheel bearings???? Been reading alot about those on here you may want to look into yours just tossing ideas out there. Jacked it up and my husband had a hard time getting any movement up and down correct me Kyle if i had him do that incorrect.
polarbear18w
13
Sep 23, 2011 01:27 PM
vdog
Jan 10, 2007 04:46 PM
