Tips to Replace Steering Components Please
Old Nov 3, 2011 | 10:51 AM
gatorboy44's Avatar
gatorboy44 is on a distinguished road
Lightbulb Tips to Replace Steering Components Please
I'm going to replace my lower balljoints, pitman, and idler arm myself, does anyone have suggestions as to how to make the process easier or problems I may run into? (I'm not replacing the upper ball joints because when I buy the Rough Country 2.5" lift, the upper control arms include upper ball joints.)
Old Nov 3, 2011 | 11:08 AM
Irocz327's Avatar
Irocz327 will become famous soon enough
I've heard that if your ball joints never been replace since the factory that you need to take an air chisel to the rivits or at least a hammer & chisel. The new ball-joints are suppose to come w/ bolts to replace the rivits.
Old Nov 3, 2011 | 12:01 PM
gatorboy44's Avatar
Yeah I've heard that before, i'm pretty positive they have never been replaced.
Old Nov 3, 2011 | 02:06 PM
warthogdriver's Avatar
when i did my pitman i removed the steering box, i think its the only way to really work on it....it will be a PITA to remove if its anything like mine was.
the idler and lowers will be cake compared to the pitman.
just make sure you have a fork for the idler and you will be fine.
Old Nov 3, 2011 | 03:07 PM
TMM217's Avatar
TMM217 is on a distinguished road
Yeah use a cut-off wheel and grind off heads of factory rivets on the lowers, same as top if your using factory arms them just use a punch and knock out rivets simple simple. As for the pitman arm Im sure u have to remove the steering box on a 4 wheel drive not sure on a 2 wheelr.
Old Nov 3, 2011 | 03:37 PM
gatorboy44's Avatar
What else is involved in removing the pitman arm?
Old Nov 3, 2011 | 03:43 PM
chris015's Avatar
nothing really,just the process of removing the steering box. Once you get it out flip it over and remove the huge nut on it. im not sure what size it is. remove it then put the puller on the Pittman and tighten it until it pulls off the steering box.
Old Nov 3, 2011 | 03:47 PM
gatorboy44's Avatar
Looks like this will be a blast lol but well worth the $600 saved that will cover the cost for my lift kit
Old Nov 3, 2011 | 09:45 PM
98blazin's Avatar
98blazin is on a distinguished road
i removed my pitman arm on my 98 4x4 simply by unbolting the steering box from the frame(but keep it there with hoses attached), and using a ''C'' puller and a impact gun it took about 25mins.
including the removal of the front factory skidplate.
factory ball joints, grind the rivets off or drill them off. pretty simple too.
Last edited by swartlkk; Nov 4, 2011 at 07:10 AM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Nov 4, 2011 | 07:08 AM
gatorboy44's Avatar
Yeah doesn't look too bad at all.
