Today....lower control arm bushings
Old Dec 5, 2010 | 12:51 PM
Frequency4one's Avatar
Frequency4one is on a distinguished road
I'm having a heck of time getting the bushings out of the control arm. I've heard that some are welded in. This may be the case with mine.
Old Dec 6, 2010 | 08:04 AM
69chevelle's Avatar
69chevelle is on a distinguished road
I knocked both end caps off with an air chisel(hammer and chisel will work), cut the rubber bushing off on the outside, tighten the center sleevve in a vice and twist the control arm untill it comes free and wiggle it back and forth to get it out(I used the ball joint press for this... Remove the rubber bushing, then with a hammer and chissel I 'collapse' the outside sleeve and it fell right out
Old Dec 6, 2010 | 08:46 AM
cage47's Avatar
cage47 is on a distinguished road
Yep. There's a reason it takes a heavy-duty c-clamp to get them out. They are supposed to be tight. It'll take some doing but I doubt yours are welded in. What year is it?
Old Dec 12, 2010 | 08:56 PM
It's a 97. Thanks for all the advise. This forum came in handy. I dropped the control arms off at a local shop and had them remove the old and install the new bushings. It cost me what they charge for an hour of labor, even though I don't think it took but 30 mins. But $57 later, I didn't have to worry about damaging anything. I finished the job today, replaced all bushings, the halfshaft, ball joints. Learned a lot....might do it again someday. For now...I'm taking a break.
Old Dec 17, 2010 | 11:26 AM
01lsok's Avatar
01lsok is an unknown quantity at this point
I've done front suspension work on a 2001, my sujestion is if it's not broken don't tamper with it. These 4WD drive modles are tempermental when it comes to re-aglinment.
If you believe that you're a good enough to do it, make sure the orientation is scribed and just not marked with a pencil. That was my bigest mistake and it has never rode the same since.
Which leads me to my question; does anyone have a photo of factory set upper control arm cams?
I also found that if you just torch the bushings and punch them out, is easier than struggling with a c-clamp or a vice.
Old Dec 18, 2010 | 03:16 PM
petermcg's Avatar
petermcg is on a distinguished road
Can any one give me the part no or a picture of what the Pitman arm should look like for a 99 Blazer 4wd,RHD as in Japan and New Zealand, as they are different to the LHD ones.
Last edited by petermcg; Dec 19, 2010 at 02:49 AM. Reason: I should say that it is a RHD model pitman arm details I am looking for.
Old Dec 19, 2010 | 10:01 AM
cage47's Avatar
The problem with that is that you can warp or damage the control arm while torching it. I had it happen when I had it done (at a shop no less) for an older dodge van. And That was a beefier control arm. But it was rendered useless from the torching.
Petemcg. Try posting a new post for your question. It's uncool and counter productive to hijack an unrelated thread.
okiedoak20
Jun 26, 2013 08:53 PM
wild bill
Feb 8, 2011 07:20 PM
cage47
Jun 11, 2010 12:17 PM
PaulO2288
Mar 13, 2010 09:01 PM
Major Pain
Suspension Tech
Dec 17, 2005 08:37 PM
