Torsion bar from another model
Old Aug 18, 2010 | 03:02 PM
TripleBlackBlazer's Avatar
Found out these are GL code torsion bars. They are one step below the highest on the list I linked to earlier. 8782 is the torque rating in ft/lbs. I'm still curious as to what our Blazers' torque rating is.
GL
8782 15528965 (LH) 15528966 (RH)
Old Aug 18, 2010 | 07:33 PM
8782ft/lbs?? WOW!
A little under 4 times as high as the highest s-series bars:
Originally Posted by jsmz
Yep, first off the chilton manual says to push the bar forward into the control arm, drop it out of the cross member and pull out the back. but after droping the bar, its at an angle that doesnt like to pull out
I have a better way, tap both bars forward enough to drop the keys out. then unbolt the two cross member bolts & drop that out. then pull the bars straight out the back.
now that ive said that here is the list of bars gm made
Part Number Bar Dia. NOM Torque
LH 15956501 26.63mm 1052
RH 15956502 26.63mm 1052
LH 15956503 27.94mm 1276
RH 15956504 27.94mm 1276
LH 15956505 29.36mm 1450
RH 15956506 29.36mm 1646
LH 15956509 30.69mm 1883
RH 15956510 30.69mm 1883
LH 15956511 32.51mm 2305
RH 15956512 32.51mm 2305
The old ones had settled two inches since i got it. they were the 27.94mm bars. Put in the 30.69mm bars off a 03 zr2 with 33,xxx miles. I must say, it drives more like a 4x4. feels alot more stable going over bumps.
Old Aug 18, 2010 | 07:41 PM
cbr995's Avatar
I have a feeling the bars would be much larger than the openings you have. I may be wrong, though.
Old Aug 18, 2010 | 09:14 PM
Yes, I did read that the higher the rating, the thicker the bar. Makes sense.
I just saw them for $25 and low miles and I started to salivate.
Originally Posted by swartlkk
8782ft/lbs?? WOW!
So unless I plan on towing backwards, these are a bad idea...LOL
Old Aug 19, 2010 | 02:06 AM
ImScrewed92's Avatar
^Do you really need that strong of a bar to hold up the front end with the brush guard? lol. BTW I really like the image of your blazer with the camaro SS wheels in your sig. Looks like it will really stand out from the rest, yet look like it could have been bought off the dealer lot like that.
Old Sep 1, 2010 | 08:05 PM
It's not to hold up the weight of the brush guard. My passenger's side t-bar is nearly maxed out and it still sags lower than my driver's side which only has a few cranks on it.
Thanks about the SS rims. I can count the amount of S-Series trucks I've seen with these rims on one hand. And I believe most of those have been lowered. The only other one I saw that was lifted had them painted black.
Old Nov 7, 2010 | 07:20 PM
jacobrollins's Avatar
jacobrollins is on a distinguished road
Originally Posted by Blazn1
I got zr2 bars in my 2nd gen 4 door, work great!
Do they lift any and whats the difference between zr2 torsion bars and a regular blazers torsion bars?
Old Dec 13, 2010 | 08:20 PM
ZR2 bars are thicker and have more load capacity. Word on the street is that about half cranked on the ZR2 bars is maxed out on stock ones, and you still have room to lift.
Old Dec 14, 2010 | 01:37 PM
Blazn1's Avatar
Blazn1 is an unknown quantity at this point
I fought with the zr2 bars for about a month and they are working good and beefy!
azzr2
Mar 25, 2012 04:19 PM
mmastrac
Sep 19, 2010 09:43 PM
sledneck16
Suspension Tech
47
May 20, 2009 12:56 AM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
Bgray
Suspension Tech
Sep 10, 2006 04:45 PM
