Torsion Bar Help
Old Oct 30, 2008 | 07:52 PM
dew88's Avatar
dew88 is an unknown quantity at this point
Default Torsion Bar Help
I have read until I feel like my eyes are going to bleed. I am unsure and confused on this matter. I followed the torsion bars all the way to the back of the torsion bar where I found a key on the end. How do I adjust the torsion bars? Is there pictures somewhere or a good illustration I can read?
I normally don't post blind posts like this but I have never had a IFS before. All I have ever had a SFA. Thanks
PS If pics are needed I can take some. Thanks
Old Oct 30, 2008 | 07:57 PM
WolfPack's Avatar
Default RE: Torsion Bar Help
alllright fine
So...if you follow the tbar all the way back to the crossmember where the key is, you'll see the torsion bar adjuster bolt. It's a big bolt, I believe 3/4'. You tighten the bolt to raise the front end..1 full turn of the bolt = .2'-.25' of lift based on how worn your bars are.
The trick with measuring the height of the front end after you make a couple turns is to work the suspension out. It's best to drive down the street and back. Then measure.
I'll see if I can find you a pic of the adjuster bolts...but if you found the keys, you shoulda found the bolt
Old Oct 31, 2008 | 05:44 AM
mysons95's Avatar
mysons95 is an unknown quantity at this point
Here is a picture of the rear end of the passenger-side torsion bar where you adjust it.
When you turn the bolt, it moves the key, which adjusts the bar, which raises or lowers your truck.
Clockwise = raise
Counterclockwise = lower
No more than 1.5" total raise unless you want to wear out parts faster.
Old Oct 31, 2008 | 07:35 AM
WolfPack's Avatar
Nice pic! Still muddy I see
Old Oct 31, 2008 | 11:04 AM
dew88's Avatar
Thanks so much guys I feel like a complete ***, I was right under and never seen it. LOL..
I like the SFA better, easier to lift. Is the torsion bars my only means of front end lift with the IFS?
Old Oct 31, 2008 | 12:37 PM
WolfPack's Avatar
Your torsion bars are your front suspension...so...just like lifting a SFA (coils/leaf), you gotta work with what youve got!
The only other options is a full kit from Superlift, BDS, or Trailmaster. The 2' kits give you better angled upper control arms to help the front end...and the 5/6' kits give you a whole assortment of brackets to drop the diff back down keep your CVs at safe angles. They still use the torsion bars as the suspension system.
I rather like the IFS though...
Old Oct 31, 2008 | 01:57 PM
dew88's Avatar
In theory I like the IFS aswell however I see the Half shaft axles to be a pain in the ****. I already have a Dana 30 Jeep front axle with leafs and all. I have crossed the idea of a SAS but I don't weld.
Old Nov 13, 2008 | 06:00 PM
ptg327's Avatar
ptg327 is an unknown quantity at this point
i have a banging noise under my truck which everyone of my friends says its the torsion bar. i have a question and that would be is if i adjust the torsion bar bolts will the noise go away and in the process get a little bit of a lift outta the deal. the noise is coming from under the floor board where the passenger would put their feet. kinda close to the seat.
Old Nov 13, 2008 | 06:14 PM
mysons95's Avatar
ORIGINAL: WolfPack
heh
Old Nov 13, 2008 | 06:48 PM
ORIGINAL: ptg327
Sounds like a busted mount on the passenger side of the torsion bar crossmember. Tightening down on the adjustment bolt will give you some lift, but it will not cure your problem.
azzr2
Mar 25, 2012 04:19 PM
dj00140
Mar 2, 2011 08:52 AM
musclecar70sfan
Aug 15, 2010 06:45 PM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
Bgray
Suspension Tech
Sep 10, 2006 04:45 PM
