torsion bar problem
Old Dec 15, 2012 | 04:33 PM
sputnik's Avatar
sputnik is on a distinguished road
Default torsion bar problem
i replaced some parts including the lower control arms. i removed the lower control arms, torsion bars, and torsion bar crossmember all as one piece since they were coroded so badly. when i removed everything the front end didnt sag at all it was where it should have been, the key bolts were screwed in almost all of the way. i put it all back together the way i took it apart but the front end sits all the way down on the control arm bumpers. im hoping maybe somebody here might have an idea of what im not figuring out. thankz for any help
Old Dec 15, 2012 | 05:10 PM
coolasice's Avatar
coolasice will become famous soon enough
sounds like you may be off a notch on either the key or the lower control arm when you reinstalled the torsion bars
Old Dec 15, 2012 | 06:36 PM
sputnik's Avatar
i had the lower control arm disconnected from the steering knuckle put the torsion bar into the arm in the notch where the key was horizontal then tightened the key bolt and attached the control arm to the steering knuckle. if i would of put the torsion bar in the notch in the control arm clockwise i wouldnt be able to install the key because it wanted to face up too much and if i would of put the bar in counterclockwise one notch the key would face down too much to get the bolt in. i tried those just to make sure i had it in right. now that i think of it i didnt make sure i put them on the side of the car they came off of although i doubt that would make a difference
Old Dec 15, 2012 | 06:41 PM
neo71665's Avatar
There is a right and left. If I recall mine had L and R on the end.
You are using the tool to take the tension off the keys right?
Old Dec 15, 2012 | 07:12 PM
sputnik's Avatar
guess i check that tonight make sure i got them on the right sides. and yes im using a two arm puller to unload the tension. thanks for the help guys
Old Dec 15, 2012 | 11:42 PM
sputnik's Avatar
indeed i feel like an idiot now. i had the torsion bars switched around (left on the right and right on the left). i adjusted the keys bolts a couple of times and got it close to where its suppose to be until i can get it aligned next week. thankz for the help
02blazerkyle
Lifting Tech
Oct 26, 2013 05:21 PM
azzr2
Mar 25, 2012 04:19 PM
hateitorlikeit
Lifting Tech
Jun 9, 2011 10:08 AM
Eric0072
Lifting Tech
Aug 19, 2008 08:19 PM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
