Total noob question about shocks
Old Jan 25, 2010 | 03:27 AM
ScottWV's Avatar
ScottWV is on a distinguished road
Default Total noob question about shocks
Hi everyone!
I'm brave enough to admit that I'm in my mid 30s and finally getting brave enough to do work on my own vehicles beyond oil changes.
I don't know much about shocks, but I know the ones on my Blazer are in need of changing.
My question is can I gain some lift by putting on new shocks? I'm not looking for a skyjacker, but putting a little more air under it would be pretty cool without investing in a lift kit just yet.
Thanks!
ScottWV
Old Jan 25, 2010 | 06:20 AM
leeclark's Avatar
leeclark is an unknown quantity at this point
no you wont get lift from shocks. if you want lift you have to do a body lift or shackles and t-bar crank. or both.
Old Jan 25, 2010 | 07:15 AM
That is a loaded question. If you are replacing the shocks with stock replacements, you will get no lift from a shock. Shocks do not actually add spring rate to the suspension, they simply dampen out oscillations.
With that said, you can get spring over and air shocks which can add spring rate. These are only available for the rear of the truck and are meant to retain ride height with an increased load on the rear suspension. They should not be used to supplement sagging rear springs since you really are not addressing the problem, only putting a band-aid on it.
buckmaster299
Nov 14, 2012 10:18 PM
FirePhage
Apr 19, 2011 12:56 PM
jellyphish97
May 9, 2009 08:31 PM
XBlazer01
Aug 13, 2006 07:00 PM
strongboy2005
24
Mar 27, 2006 11:21 AM
