transfer case fluid
Old Sep 13, 2012 | 10:10 PM
kody070's Avatar
kody070 is on a distinguished road
Default transfer case fluid
Anyone got a trick for filling the transfer case? Mines a real pta! I did get the right fluid auto trax 2 for my 01 zr2 blazer ls with 4 button push. The hole is so small and hard to get anything up in there to fill it
Old Sep 13, 2012 | 10:16 PM
depdog1968's Avatar
depdog1968 is on a distinguished road
I drilled a hole in the lid and threaded a hose nipple on the lid, Attached a clear rubber hose on and squeezed the bottle. It worked great and I did not spill a drop. I got the hose nipple off of an old lawn mower engine.
Old Sep 13, 2012 | 10:31 PM
chris015's Avatar
Getcha some fuel hose,(i cant remember the size i used,but the diameter needs to be big enough that you can fit the quart of fluid in it and it not slip out)
You need it to be about 4ft long. If you look at the torsion bar cross member you'll see 1 or 2 holes about a inch big in the center,run the hose through it,into the tcase. now wedge your bottle into the hose and squeeze. Reason for the long hose it lets you get above the tcase and you'll have more room behind the crossmember to do that.
Tcase fill SUCKED. i wont do it again for the life of my blazer lol.
Old Sep 13, 2012 | 10:36 PM
kody070's Avatar
Haha thanks I did end up rigging a way spilled a lot st first though. I never wanna do it myself again. Does 2 quarts sound right to fill it? I got 2 in it plus little bit of next one but that's with spilling
Old Sep 14, 2012 | 06:42 AM
aa21830's Avatar
aa21830 is on a distinguished road
2 qts is about right.
Old Sep 14, 2012 | 08:40 AM
mrspeedy69's Avatar
mrspeedy69 is an unknown quantity at this point
I recommend getting a transfer pump. I bought one from harbor freight and it worked awesome. Pumped 2 quarts in and only had a little leak from the fill plug. It took me all of maybe 10mins to do.
Flyfishen
Jun 18, 2019 11:22 AM
DaleA
Jan 13, 2009 08:50 PM
AutomagicLS1
Engine & Internal
Dec 1, 2006 11:08 PM
blazerium
Nov 20, 2006 11:10 PM
Marcin
Oct 14, 2006 06:09 PM
