transfer case vacuum switch
Old Sep 26, 2015 | 05:18 PM
nbguide's Avatar
nbguide is on a distinguished road
Default transfer case vacuum switch
I have vacuum to the actuator under the battery and it pulls the engaging cable but not quite far enough. When engaging with battery removed (but running) the actuator pulls but doesn't engage, when i pull the cable .5 inch farther it engages the front axle.
Would a bad transfer Case Vacuum Switch cause this?
Old Sep 27, 2015 | 04:40 AM
jpjones55's Avatar
jpjones55 is on a distinguished road
From all the videos I've recently watched on the subject, that sounds like the problem. I had a bunch of dry rotted vacuum lines at the top of the engine compartment right in front of the drivers side. but i still need to test my actuator, but will probably need to replace the switch.
Old Sep 27, 2015 | 06:03 AM
nbguide's Avatar
I replaced a bunch of vacuum lines under the hood and figured this was the last remaining problem. I can't reach my hands up in there SO I'm going to cut a hole above it in the floor with a hole saw to get easier access to it. I'll let you know if this was the problem.
Old Sep 27, 2015 | 06:29 AM
jpjones55's Avatar
Do you have the 3 button switch in the dash or the 4 button one? from what I've researched here, the 3 button switch has the vacuum switch on the xfer case on the drivers side. The 4 button switch has a solenoid mounted under the hood in the middle top firewall area....
Old Sep 27, 2015 | 09:35 AM
10-78 edac's Avatar
10-78 edac is on a distinguished road
STOP, don't cut it. you can reach it from underneath.
It's 7/8", Should take only 2 min.
Old Sep 27, 2015 | 03:29 PM
nbguide's Avatar
already hole sawed it and replace. You can reach it, but barely. I dont have carpet in my blazer so it was no big deal to cut and replace. It didnt solve my lack of vacuum issue though. might just go the posi lock route now.
Old Sep 27, 2015 | 06:09 PM
nbguide's Avatar
posi lock kit ordered
cjb2145
18
Oct 6, 2018 04:46 PM
paulp64131
Dec 26, 2011 03:52 AM
slowhand
Jan 5, 2010 05:14 AM
SockJock
Mar 4, 2009 11:55 AM
fred96
Jun 8, 2007 11:23 AM
