U-joint problem.
Old Nov 20, 2007 | 08:00 PM
S10Blazer's Avatar
S10Blazer is an unknown quantity at this point
Default U-joint problem.
Ok, so I recently got my truck back from the mechanic before he closed. He replaced both U-joints that were on the rear shaft. Now, I have noticed that when I accelerate, the whole truck vibrates, and it gets worse if I accelerate more. What could this be? I am going to take it back to him tomorrow, but I just wanted to know what could be the problem.
Old Nov 22, 2007 | 05:53 AM
S10Blazer's Avatar
Default RE: U-joint problem.
Ok, my mechanic said that I should drive the truck at 50 mph or more, so that the new u-joints could adjust.
Old Nov 22, 2007 | 10:04 AM
rriddle3's Avatar
Hmmm, that's a new one to me. Never heard that before.
Old Nov 22, 2007 | 05:06 PM
S10Blazer's Avatar
Well, actually this morning, I decided to run it at 50 mph and higher, to see if it would go away. It's really bad. The truck vibrates a lot. It does it even more when I hit 60 mph. I am going to take it back to him first thing in the morning on Monday. Also, when I am cruising(not giving it gas) at a low speed, it makes a loud, ugly sound as if some metal parts are moving. And as I said, the truck vibrates very much. my radar dectector and gps almost fell off the windshield from rattling so much. What do you guys think?
Old Nov 22, 2007 | 07:19 PM
TripleBlackBlazer's Avatar
Sounds like he didn't index it properly. My guess is he didn't mark the driveshaft when he took it out so when he replaced it, the weights were in the opposite side (where they were stock) which is giving you that nasty vibration.
EDIT: I would have a hard time bringing it back there after he fixes his problem. The advice to drive it over 50 so that it will adjust...shady.
Old Nov 22, 2007 | 09:01 PM
S10Blazer's Avatar
Yea, I've known him for quite a few years, and this is the first problem I have with him. But I will definitely go to him with an attitude. It didn't cost a penny either. He had replaced the heater core for me along with this joint, and it was not cheap at all. Do you think anything could get seriously damaged by running the truck in this condition? Thanks again for all your help.
Old Nov 22, 2007 | 11:45 PM
Chevy Lover's Avatar
ORIGINAL: S10Blazer
...this is the first problem I have with him. But I will definitely go to him with an attitude...
I wouldn't go with an attitude, if someone comes to me with with an attitude I just return the same to them.
I'd go back to him and let him know that there's a major vibration problem and that a friend mentioned that the drivehaft may have been installed 180deg out ( not indexed), and that could throw the driveline out of balance.
Then see if he's willing to adjust the shaft for you. ( it only take a few minutes on a hoist).
Everyone can have a bad day and make a mistake. If he doesn't want to fix it, then go for the attitude!
I wouldn't run the truck with the vibration any longer than you have to and keep the speed down, then there should not be any damage to the truck.
Old Nov 22, 2007 | 11:57 PM
S10Blazer's Avatar
ORIGINAL: Chevy Lover
ORIGINAL: S10Blazer
Well, that is true. I mean, the only reason why I'm kind of mad is because I paid a lot for all of this, and I expected the best. But it is true, people can make mistakes. What exactly is the process to fix it? Does he have to take off the drive shaft, and adjust or rotate the joint? By "indexed", do you mean that it is not centered?
Old Nov 23, 2007 | 11:59 PM
He doesn't need to take the driveshaft off. Just remove the rear u-joint clamps, push the driveshaft forward enough to clear the rear diff flange, rotate the diff 180 degrees, slide the driveshaft back into position and bolt it back up.
Indexed refers to the position of the driveshaft to the rear axle flange. most people will mark the flange and the driveshaft with paint before removing the driveshaft to make sure they put it back together the same way it came apart....for balance reasons.
Old Nov 26, 2007 | 08:33 AM
cain45's Avatar
cain45 is an unknown quantity at this point
If I may ask, what did it cost to have the heater core replaced?
josemateos
Feb 18, 2014 10:00 AM
Blazer98guy
Nov 14, 2013 10:34 PM
Guntheone
Dec 4, 2010 05:59 PM
97Bravada
Jan 14, 2010 05:51 PM
danyboy
Apr 8, 2009 01:38 PM
