Upper control arm 4x4
Old Oct 29, 2017 | 05:10 PM
Finally got around to installing my upper control arm this weekend. A lot easier then expected. Biggest problem I had was when I put back together the passenger side I pulled out my cv axle. But got it all back together.
Getting the driver side done I got an early Christmas gift from the blazer. I have a shot shock absorber! Less then a year and it's already gone... gonna get a cheap one to get me threw my road trip and change them to a blestein set in the new year.
90$ for the pair of control arms with bushings and ball joints pre installed. Happy with the price but just gonna see how long they last.
Old Oct 29, 2017 | 05:33 PM
Here are the pictures I took of the work
Attached Thumbnails Upper control arm 4x4-20171028_114716.jpg   Upper control arm 4x4-20171028_114723.jpg   Upper control arm 4x4-20171028_130943.jpg   Upper control arm 4x4-20171028_130947.jpg   Upper control arm 4x4-20171029_141055.jpg
Upper control arm 4x4-20171029_141105.jpg   Upper control arm 4x4-20171029_160821.jpg   Upper control arm 4x4-20171029_164005.jpg
Old Nov 7, 2017 | 06:36 PM
So since I've done the control arms... I have been keeping an eye out on my tire angles. And so far my driver aide is better but my passenger side has gone back to being on an angle, only a few days after. I will be taking it to a shop to get advice.
the only good news from the blazer is that I got my heat back! But woke up to a dead stereo deck...
Old Nov 15, 2017 | 12:58 PM
Glad you got them done.
Looking at your last picture with the tire tread in the foreground, it looks like you have quite the angle on the CV joints. Did you do a torsion-bar lift? If so, I'm wondering if you could share why you did not go with aftermarket upper control arms (e.g. Superlift or Rough Country) that are designed to compensate for the new angle for the upper ball joints.
Old Nov 15, 2017 | 01:54 PM
Hadyss's Avatar
I had to do my upper bushings and ball joint in aug but I wanted a lift to so just went with the rough country 2.5" lift. it came with the control arms for the torson lift figured it would be cheaper in the long run. And ya the winter is already rough up here in sask
Old Nov 15, 2017 | 03:54 PM
I've bee wanting to get the 2.5" lift kit from rough country, but my budget is what' holding me back from getting it. The blazer is my dd and I need it on a daily basis. So I gotta get what I can afford at the time unfortunately. Come the new year I will be sneaking money to the side in order to get it.
unfortunately I am currently looking into my lower control arms and ball joint... I believe I might have bent something last time I hit a pothole
Old Nov 15, 2017 | 03:59 PM
Hadyss's Avatar
I had to sneak it away for the kit too with the exchange rate and quick shipping cost about 1000 then 71 for import fees. I found out the shop next to my work sells them after I ordered online and they do like a payment plan for it. Maybe check some shops
Old Nov 15, 2017 | 04:15 PM
When I did my lift I did not get the whole RC lift-kit and instead went with only their upper control arms an then got different shackles that were a tad shorter than the RC ones which would have been too long for the 2" lift I was doing. This also meant I did not have to modify the IFS axle.
I totally get the calculus concerning price and having it be a DD. Mine is a bit of a daily driver too.
Old Nov 15, 2017 | 04:18 PM
Hadyss's Avatar
Mine is the only dd we have so I did it in 2 weekends rear first then the front the next weekend but I saved a lot for it just prayed my bushings would last long enough. I did my idler arm while I was doing everything but I got the steering stabilizer at the same time. I’ve seen on here you can get the drop brackets for the front diff from rough country if u call them
Old Nov 18, 2017 | 05:15 PM
I got my tire angle fixed... next time I should realigned my toe angle before thinking the truck is broken lol.... but the old bushings did throw it off angle.
