Upper control arm
Old Mar 25, 2018 | 08:44 AM
gocart879's Avatar
gocart879 is on a distinguished road
Default Upper control arm
Have a 2000 4x4 LS. I looked around on this site and it was hard to get an exact answer, so I apologize if I am duplicating.
I have to replace upper and lower ball joints which is something I can easily do. After reading into it, there was a discussion about upper control arm bushings so I decided to take a look at mine. I have never replaced them in 104,000 miles and the rubber is dry rotted pretty good. I have not noticed any noises or squeaks to concern me however.
I figured I should replace the upper control arm instead of just doing the ball joint, would I be wrong thinking otherwise ? I replaced front shocks a couple years ago, so the bolts should be fine to remove, but I was wondering if I need to remove a shock bolt to get the control arm bolts out of the way, or can I work around this some way ?
The lower control arm seems to be more difficult to change out, so I was hoping to leave it alone. But I would be open to suggestions Thanks
Old Mar 25, 2018 | 11:44 AM
Strangerock's Avatar
Strangerock is on a distinguished road
The new control arm will most likely come with a cheap chinese ball joint.
Old Mar 28, 2018 | 11:32 AM
Not if you purchase a name brand unit such as Moog (which I would highly recommend). But yeah if you just go with the cheapest one on eBay you can find then you're just setting yourself up to rip it back apart again and replace it again in the not-so-distant future...
My honest opinion, if you're questioning it, go ahead and do it. You have to get an alignment (at least you're suppose to) after just replacing the ball joints, you'll have to get an alignment after replacing the control arm. You might as well just knock them both out and only have the alignment done once.
And I would recommend removing the shock, if anything it'll give you more room to work, and it's only 2 bolts...
cage47
Jun 11, 2010 12:17 PM
99whiteblazer
Oct 27, 2007 01:24 AM
TripleBlackBlazer
Sep 19, 2007 08:48 PM
Marcin
Nov 11, 2006 10:03 PM
Major Pain
Suspension Tech
Dec 17, 2005 08:37 PM
