Vacuum actuator switch
Old Aug 25, 2008 | 04:16 PM
watsonracingteam's Avatar
watsonracingteam is an unknown quantity at this point
Default Vacuum actuator switch
Can someone describe how this thing works or point me in the direction of a post that does?
I have been in 2WD for about 2 years. I had some grinding on start up until it built up some vacuum.
What was in or out up or down before I built up pressure and after I built up pressure???
Was I locked up in some way to effect ride and MPG?
Brian
Old Aug 25, 2008 | 04:48 PM
Default RE: Vacuum actuator switch
The switch on the transfer case is likely bad. The switch is activated by the transfer case when it shifts into a 4wd mode and directs vacuum pressure to the front axle actuator under the battery tray. If you have vacuum at the actuator all of the time, the front axle is active and will cause your mileage to suffer as well as possibly some binding while turning.
cjb2145
18
Oct 6, 2018 04:46 PM
50Chevy
Jan 5, 2013 04:44 PM
PaulO2288
May 21, 2011 05:31 AM
markrd
May 8, 2009 01:39 PM
rooster
Feb 18, 2007 07:16 PM
