Vibration at highway speeds
Old 07-23-2018, 11:28 AM
iceblue068's Avatar
iceblue068 is on a distinguished road
Default Vibration at highway speeds
I have vibration at highway speeds , I've rotated and balanced my tires, changed u joints, added hub centric rings although the vibration lessened after the hub centric rings were installed. I don't know what else to do. Any suggestions?
Old 07-23-2018, 12:29 PM
newguy's Avatar
A bent rim will do that also
Old 07-23-2018, 03:11 PM
iceblue068's Avatar
How can I have my rims checked ?
Old 07-23-2018, 07:49 PM
A good way to tell is by how many weights they need to put when you balance your tires... if there isn't many, you will want to bring them to you local tire shop yo have them tested.
Old 07-23-2018, 07:59 PM
newguy's Avatar
a tire shop can tell you
Old 08-01-2018, 07:29 PM
Radar696's Avatar
Radar696 is on a distinguished road
Have you checked the steering components?
It could be you have a tie rod end going bad, if you are running over size tires it puts a lot of strain on that system.
Also you mentioned u-joints.
Is this truck 4-wheel drive?
So you are talking about the u-joints in the front axle?
I had a friend at work once with a CJ-7.
Couldn't figure it out, even after putting in a steering stabilizer.
Ended up being a bad u-joint in the front axle.
It could also be a ball joint going bad.
I would just give it all a really good look.
Radar
Old 08-10-2018, 03:29 PM
iceblue068's Avatar
My Blazer is 2 wheel drive
MArseyus
01-06-2013 12:09 PM
dano440
05-12-2012 07:53 PM
MrMopar+GM
09-06-2010 10:38 AM
ksibley603
01-09-2008 10:11 PM
syrblitz19
06-17-2006 09:13 AM
Quick Reply: Vibration at highway speeds
