Vibration in rear end (bad)
Old Dec 30, 2018 | 12:51 PM
dsamko's Avatar
dsamko is on a distinguished road
Default Vibration in rear end (bad)
Bad vibration in rear end as speed increases. Right side hot after drive to work. Took off caliper, there is play in axle 1/2 inch. Axle problem?
Old Dec 30, 2018 | 01:11 PM
cleburne red's Avatar
Could be a bad axle bearing. Do you have any gear oil leaks there as well?
Old Dec 30, 2018 | 02:20 PM
dsamko's Avatar
Dont see any leaks, going to check dtive shaft now
Old Dec 30, 2018 | 02:41 PM
Reason I ask, is I had a lot of play in one axle shaft once. The axle shaft itself had worn to the point where it was loose on the bearing, and would wobble around, kill the bearing and seal, and leak gear oil
I never noticed any vibrations, though.
blazer_fan
Jan 6, 2014 10:07 AM
jmaynard
Jul 12, 2011 01:03 PM
Gearhead52
Mar 1, 2011 04:18 PM
NVANZEE
Jun 22, 2009 11:04 PM
luzznit
Nov 2, 2008 09:36 AM
