weird squeaking coming from rear end/ driveshaft
Old Jul 16, 2007 | 09:32 PM
stevelknievel's Avatar
stevelknievel is an unknown quantity at this point
Default weird squeaking coming from rear end/ driveshaft
ok guys and gals, i recently noticed that when im in reverse there is this squeaking coming from my rear end/driveshaft area. i jacked it up and turned everything by hand and heard nothingbut couldnt put it in reverse while it was jacked up (didnt have my jackstands and i have really bad luck). does anyone know what could be causing this?
Old Jul 16, 2007 | 10:29 PM
Default RE: weird squeaking coming from rear end/ driveshaft
I had a very similar situation with my old Bravada. Rear u-joint had seized. If the rear joint has not been changed before, it is retained by injected nylon. You will need to heat the yoke while you press the cups out. It is easiest to do with a hydraulic press, but can be done with a few sockets and a bench vise. But heat is a must. That nylon is tough. Once you get the cups out of the driveshaft, file down the inside surfaces on the yoke to make sure that htey are cleaned up and ready for the replacement cups which will be held in by C-clips.
While you're doing one, it's often just as easy to replace the other. But that's up to you. And remember, if the new one has a grease zerk on it, grease it every time you change your oil along with the zerks on the front suspention and steering.
Old Jul 16, 2007 | 10:31 PM
thanks man! i really appreciate the help
Old Jul 17, 2007 | 07:47 PM
thanks again for the help man. everything went real smooth except for the old u joint blowing up in my vice haha
Old Jul 17, 2007 | 08:13 PM
Yeah, that happened with mine as well. LOL
Kylendm
Dec 6, 2013 02:54 PM
gitch93
Jan 23, 2013 04:51 PM
Radar0066
May 28, 2011 12:11 AM
caprini83
May 2, 2011 07:16 AM
rocktheguitarist
Jun 11, 2009 07:36 PM
