What Size Breaker Bar do you use for the Hub Nut?
Old Feb 24, 2012 | 11:45 PM
Flyfishen's Avatar
Flyfishen is on a distinguished road
Default What Size Breaker Bar do you use for the Hub Nut?
What Size Breaker Bar do you use for the Hub Nut? I bought a 3/4 drive 36" and now I'm looking for a deep socket 35mm 3/4 drive to go with it; which turns out is a bit hard to find around here.
Old Feb 25, 2012 | 01:11 AM
war00's Avatar
war00 is on a distinguished road
I use a 36mm 1/2" socket and impact gun or a 1/2" breaker bar with a cheater bar.
Old Feb 25, 2012 | 04:31 AM
chris015's Avatar
I use a craftsman 1/2" socket wrench with a warranty for when/if it breaks,and a big *** piece of pipe. Works awesome.
36mm hub socket is whatcha need.
Old Feb 25, 2012 | 06:26 AM
pettyfog's Avatar
Ditto!
1/2" drive is all you need for anything you will park in your driveway.
Note that 36 mm is pretty much standard for hub nuts. Used same on Taurus Tbird and Bravada. I even used 1 1/4 pvc pipe for the cheater it worked great
War no doubt has a pro level impact. The $40 ones work great for most project but wont cut it on anything over about 150 ft lbs
Old Feb 26, 2012 | 12:41 AM
Flyfishen's Avatar
The hub nuts on mine must be stuck on; I broke two 1/2 drive breaker bars.
Old Feb 26, 2012 | 01:00 AM
war00's Avatar
spray with pb blaster and let soak for a little bit and if need be use a little heat from a propane torch. Axles nuts are locking nuts too, soo it will take a little force to break them free.
pettyfog you are correct with my impact gun, its good up to 650lbs, its only a 1/2" gun and i use it to crack wheel nuts on highway coaches
Old Feb 26, 2012 | 01:37 AM
Flyfishen's Avatar
War, what kind of Impact Gun do you have? 650lbs!!!
Old Feb 26, 2012 | 02:56 AM
war00's Avatar
blue point gun with titanium parts, 650ft-lbs reverse and 550 ft-lbs forward. i perfer my 1/2" over a 3/4" or 1" guns. easier to handle. best $300 i ever spent on a tool!!! not much it cant take off.
Old Feb 26, 2012 | 02:31 PM
Flyfishen's Avatar
300 bucks; thats cheap! I'm thinking that's my fathers day gift!!!
Old Nov 13, 2012 | 10:21 AM
Lippyp's Avatar
Lippyp is on a distinguished road
Time to revive an old thread, if anyone has any tips to getting the hub nuts off lets have em. I did one side a year ago and it came off fine, doing the other side now and so far I've broken two 1/2" drive breaker bars, I've used penetrating oil, tried freeze spray. Next up is I'm just off to borrow a 3/4" drive socket set from a farmer neighbour and try that. I don't have access to an impact gun. Might have to try heat as well.
