Whats the best way to remove a front rear?
Old Nov 12, 2010 | 03:44 PM
OH_VDUB's Avatar
OH_VDUB is an unknown quantity at this point
Default Whats the best way to remove a front differential?
I have a 96 blazer, I'm trying to figure out what's the best way to remove the front differential without pulling out my hair?
Old Nov 12, 2010 | 04:36 PM
zedartwo's Avatar
What do you mean by "front rear"? kinda canceling each-other out there.
Old Nov 12, 2010 | 04:44 PM
UberFail's Avatar
UberFail is on a distinguished road
the front diff ???
Old Nov 12, 2010 | 06:04 PM
OH_VDUB's Avatar
Default Best way to remove a front differential
Sorry bout that I mean the front differential 96 blazer
Old Nov 12, 2010 | 06:54 PM
robertr728's Avatar
robertr728 is on a distinguished road
Its a fun job and the entire front end will have to be disassembled. I attached a pdf of the instructions. I did it and i removed the entire steering linkage in front and it gave a bit more room. I would suggest replacing any front end parts that are bad as you will have it all disassembled and now is the time.
File Type: pdf
Old Nov 20, 2010 | 12:59 PM
PaintPro1's Avatar
PaintPro1 is on a distinguished road
Default Front diff removal
Robert -
Not trying to hi-jack here trying to learn... can the axles be removed safely without the puller that is called out or should we get one? Do we also need a tie-rod end puller specific to this vehicle or will a generic tool from Autozone or the like get it done?
this is my 16 yr olds 1st vehicle and we know we need front-end parts as well as possibly a diff and want to make sure we are prepared before we occupy the garage and tear it down...
Thanks!
Old Nov 21, 2010 | 07:01 AM
PaintPro1's Avatar
Default What we found...
We tore into the front-end on my sons 2000 Blazer / Trailblazer and found nothing but POOR repair work... Stub axle nuts not torqued (loose), spindle to outer bearing flange bolts loose (dust shield was rattling it was so loose), tie-rod ends loose, upper ball-joints not torqued (loose). it is no wonder this truck ate a pair of what appeared to be relatively new front tires... next Sat we will pull the diff and inspect. Looks like we will need tie-rods, and possibly a diff for sure, but will need to inspect CV's, and all bearings...
Old Nov 21, 2010 | 07:59 AM
robertr728's Avatar
I pulled my cv using a pry bar. And i used a wedge fork generic one to remove the joint fittings as i was replacing all my front end parts anyway.
bertrenolds
Feb 22, 2013 06:24 PM
tony991
Jun 28, 2011 09:29 PM
96jimmyslt4x4
Jun 6, 2011 10:38 PM
bigdaddykane93
Oct 11, 2010 10:39 AM
99 Blazer 4x4
Suspension Tech
Sep 25, 2007 11:45 AM
