Will it break?
Old Nov 25, 2013 | 11:40 PM
Brandon Koharchik's Avatar
Brandon Koharchik is on a distinguished road
Default Will it break?
okay so I have a 2000 chevy blazer. the 4x4 when out because of a vaccume leak and the transfer case vacume valve was bad. there is a bad storm approaching so I had to rig up the 4x4 system for now so what I did was have the cable pulled up by a bracket and a bolt to the cable. I have the cable fully engaged so when I need 4x4 all I do is push the button and it kicks the encoder motor. my question is, is that if I leave that cable pulled, will it ruin anything in my front end or should I just get the posi loc cable kit? thanks, brandon
Old Nov 26, 2013 | 06:58 AM
rexmburns's Avatar
Super Moderator
I personally wouldn't run at hi way speeds with the from diff engaged. Check out my build thread on the first page I have a write up of a $40 posi lock that works perfect every time!
Old Nov 26, 2013 | 11:08 AM
Jamaroon's Avatar
I wouldn't be worried about running around with it engaged, that's what the bravada shaft mod does and lots of people have that with no problems. I'd be more worried about it staying engaged/working itself loose.
89beater
Tires and Wheels
Jul 22, 2007 07:22 PM
XtreeX
May 9, 2007 01:11 PM
tnblazer
Mar 26, 2007 07:29 PM
blazerium
Dec 26, 2006 01:39 PM
tee866
Sep 5, 2006 12:23 AM
