XFR Case Shifts into 4lo
Old Sep 6, 2007 | 10:53 PM
Oneness_bc's Avatar
Oneness_bc is an unknown quantity at this point
Default XFR Case Shifts into 4lo
I have a 2000 blazer and the 4lo light on the transfer case switch will intermitantly flash and shift into 4lo if I shift into neutral. I have checked and replaced a lot of the vacuum hose. Now I am looking as a switch located in the middle of the firewall (just under the hood) and the vacuum actuator. Any ideas or help would be appreciated before I tear in to this any further.
BTW - with the hose to the vaccum accuator removed from the switch on the firewall the 4 lo light doe sgo out after 30-45 seconds of running.
Thanks in advance,
Bill
Old Sep 7, 2007 | 03:29 PM
aris_unlimited's Avatar
aris_unlimited is an unknown quantity at this point
Default RE: XFR Case Shifts into 4lo
have you ran the trouble codes on it? Also I never see any harm in taking my cars to a dealer for a diagnostic only $40-50 and they can usually pin point down the problem.
Old Jun 12, 2008 | 09:29 PM
webdeath's Avatar
webdeath is an unknown quantity at this point
I have the same problem, and have no codes set. I have checked the switch wiring, vacuum hoses, and still no answer. Has anyone had a similar problem.
Please help!
ski9600
Jan 25, 2022 04:14 PM
tmoble
Jul 2, 2012 01:26 AM
Travelin Man
Aug 26, 2011 09:28 AM
MTopper
Jul 26, 2010 11:09 PM
poepoe624
Jan 10, 2010 11:48 AM
